Netflow durations
I’m using nfdump to capture netflow off of my mikrotik routerboard but I’m getting some weird results!
As you can see from the results below I’m getting a lot of flows where the duration is equal to 0, can this be right?
Is there something I’ve done wrong with my config?
Sample (duration is second column, after date & time):
1970-01-02 07:41:13.100 0.000 TCP 74.125.24.94:80 → 192.168.88.200:39864 2 80 1
1970-01-02 07:41:13.100 0.000 TCP 74.125.24.94:80 → 192.168.88.200:39865 2 80 1
1970-01-02 07:41:13.100 0.000 TCP 74.125.24.94:80 → 192.168.88.200:39861 2 80 1
1970-01-02 07:41:13.470 0.000 TCP 192.168.88.200:53572 → 69.171.235.16:80 2 104 1
1970-01-02 07:41:13.660 0.000 TCP 50.18.120.15:80 → 192.168.88.200:59169 2 120 1
1970-01-02 07:41:12.500 1.160 TCP 192.168.88.200:59169 → 50.18.120.15:80 4 232 1
1970-01-02 07:41:13.690 0.000 TCP 69.171.235.16:80 → 192.168.88.200:53572 2 104 1
1970-01-02 07:41:13.450 4.230 TCP 50.18.120.15:80 → 192.168.88.200:59151 12 12958 1
1970-01-02 07:41:12.290 5.390 TCP 192.168.88.200:59151 → 50.18.120.15:80 15 1939 1
1970-01-02 07:41:18.120 0.000 UDP 192.168.88.200:52036 → 192.168.88.1:53 2 150 1
1970-01-02 07:41:18.120 0.000 UDP 192.168.88.200:26309 → 192.168.88.1:53 2 148 1
1970-01-02 07:41:18.120 0.000 UDP 192.168.5.201:47986 → 192.168.20.11:53 2 150 1
1970-01-02 07:41:18.120 0.000 UDP 192.168.5.201:44674 → 192.168.20.11:53 2 148 1
1970-01-02 07:41:18.130 0.000 UDP 192.168.20.11:53 → 192.168.5.201:47986 2 550 1
1970-01-02 07:41:18.130 0.000 UDP 192.168.88.1:53 → 192.168.88.200:52036 2 550 1
1970-01-02 07:41:18.130 0.000 UDP 192.168.88.200:57286 → 192.168.88.1:53 2 150 1
1970-01-02 07:41:18.140 0.000 UDP 192.168.88.1:53 → 192.168.88.200:57286 2 550 1
1970-01-02 07:40:49.250 13.880 TCP 2.22.48.147:80 → 192.168.88.200:55970 3 172 1
1970-01-02 07:40:49.350 13.930 TCP 69.171.235.16:80 → 192.168.88.200:53542 3 172 1
1970-01-02 07:40:49.350 13.930 TCP 69.171.235.16:80 → 192.168.88.200:53541 4 224 1
1970-01-02 07:40:49.570 13.710 TCP 69.171.229.25:80 → 192.168.88.200:59531 4 224 1
1970-01-02 07:41:04.640 0.000 TCP 192.168.88.200:59065 → 193.1.253.139:80 2 104 1
1970-01-02 07:41:04.640 0.000 TCP 192.168.88.200:59067 → 193.1.253.139:80 2 104 1
1970-01-02 07:41:04.650 0.000 TCP 193.1.253.139:80 → 192.168.88.200:59065 2 104 1
1970-01-02 07:41:04.650 0.000 TCP 193.1.253.139:80 → 192.168.88.200:59067 2 104 1
1970-01-02 07:40:55.880 9.630 TCP 192.168.88.200:39862 → 74.125.24.94:80 18 5404 1
1970-01-02 07:40:55.890 9.660 TCP 74.125.24.94:80 → 192.168.88.200:39862 14 5162 1
Any help would be appreciated!
Thanks,
Shane
I think I figured out my problem. The durations are probably correct but are all given in milliseconds.
Is there any way to get flow durations in micro or nano seconds using nfdump?
Or is there other netflow software that does this maybe?
Thanks,
Shane
