Hi all
I have had netflow running on my router for quite a while and only recently decided to compare data usage to what my radius server reports.
The usage data did not match up at all. It was not even close…
So I had the traffic flow settings on default until 4 days ago, but then I read in some Cisco article that they recommend setting the active flow timeout to 1 minute and I also decided to increase the cache entries value.
Now I look at the last couple of days and the usage records between what radius says and netflow are still out with hundreds of megabytes.
I don’t know if I’m doing something wrong, but everywhere I hear, people say netflow data is quite accurate.
My set up at the moment is:
[admin@MikroTik] /ip traffic-flow> print
enabled: yes
interfaces: ether2-master-local,vlan109
cache-entries: 128k
active-flow-timeout: 1m
inactive-flow-timeout: 15s
[admin@MikroTik] /ip traffic-flow> target print
Flags: X - disabled
# ADDRESS VERSION
0 10.0.15.230:9996 5
I use ManageEngine Netflow Analyzer as my collector. My RouterOS is version 5.8
Any suggestions or ideas as to what I can do?
