Hi!
I try to use NetFlow in MikroTik 2.9.29 (RB532). I setup it to send data in V5 format.
I use flow-capture from flowtools to collect netflow packets from mikrotik, but flow-capture report about errors in sequences. I also check sequence numbers with tcpdump and got same results, sequence numbers is incorrect.
Is where any way to solve this?
PS. Right now i rollback to V1. It’s work fine in Mikrotik. But it is not a solution.
Thanks!
