I am a bit confused but it does not appear that NetFlow V9 data is sending appropriately. I have numerous site-to-site locations and the setup in the alternative locations (same router model) are sending data without an issue.
Right now, I have the following settings:
[jreich_admin@3978] /ip traffic-flow> print
enabled: yes
interfaces: all
cache-entries: 128k
active-flow-timeout: 30m
inactive-flow-timeout: 15s
Target set as 10.0.0.33 [Port: 4211] V9. I have tried numerous ports. The standard port is not possible here.
I ran a FW trace on the receiving router and while I can verify I am receiving SNMP data from that router I am not getting NetFlow data. I also set up a trace on the sending router and it does not even show I am attempting to send data. So while enabled it is acting like it is not.
Any thoughts?
