Netinstall 4.6
I have netinstall 4.6 and when I start it up I get an Error 0 no code found, Click on OK and netinstall shuts down. When trying to install to a USB flash drive with netinstall 4.5b I get the cannot install system files. Any ideas? I would really like to try out this software but if it won’t work…
30 views and no ideas? Mikrotik has no ideas what is causing this or a fix?
re-download it from the web now. make sure to clear your cache so you get the new file
