I needed to Netinstall the subject device. The experience was truly remarkable because it took 6 attempts before a successful install … SIX attempts —- truly unbelievable. 7.1 Stable runs very nicely on this device now. I wonder how many others give up after 3 attempts at Netinstall …. There must be a better way ….. I almost did give up after the 5th attempt but persevered and when on the 6th attempt IT appeared hallelujah….
Did you change anything between attempts ?
I mean did you find why it worked in the 6th attempt and not in the previous ones ?
On the 6th attempt — Yes I did change the version of Netinstall from version 7.1[stable] to version 6.49.2[Stable]
Changing the Netinstall version has worked for me in the past as well…
