Hello!
RouterBOOT booter 6.44.6, CCR1009-7G-1C-1S+ fails to boot and reports an error on a serial interface:
loading kernel..... OK
setting up elf image... OK
jumping to kernel code
(0,0) hv_panic: corrupt hvfs: computed CRC 0xd86e46d7, trailer CRC 0x6cef99d4
(0,0) hv_panic: fatal DTSB read miss, fault addr 0
(0,0) fatal: invalid CPA for page 0
(0,0) Saved register dump:
(0,0) r0 0000_0000_0000_0000 r10 ffff_fffd_0000_0000 r20 0000_0000_003c_0780
(0,0) r1 0000_0000_0000_0000 r11 0000_0000_0000_0000 r21 ffff_fffc_0002_b8b0
(0,0) r2 ffff_fffc_0003_2b20 r12 ffff_ffff_ffff_ffff r22 ffff_fffc_0002_b910
(0,0) r3 ffff_fffc_0010_e7f0 r13 0000_003f_fff0_007f r23 ffff_fffc_0002_b8a8
(0,0) r4 ffff_fffc_0004_3a98 r14 ffff_fffc_0013_0abe r24 ffff_fffc_0010_e6a0
(0,0) r5 ffff_fffc_0012_a5d0 r15 0000_0000_0000_0036 r25 ffff_fffc_0010_e688
(0,0) r6 0000_0000_0000_1000 r16 0000_0000_0005_fcb9 r26 ffff_fffc_0010_e690
(0,0) r7 0000_0000_0000_0080 r17 0000_000b_e14b_ba37 r27 ffff_fffc_0010_e658
(0,0) r8 0000_0000_0000_2600 r18 0000_0000_0000_000f r28 ffff_fffc_0010_e650
(0,0) r9 ffff_fffc_0016_3018 r19 0000_0000_0000_0005 r29 ffff_fffc_0010_e660
(0,0) lr 0000_0000_0000_0000 sp ffff_fffc_0003_3c20
(0,0) im 0000_003f_fff0_007f ex0 ffff_fffc_0000_62a0 ex1 0000_0000_0000_0003
So I am trying to update OS with Netinstall but it does not detect the router.
Wireshark shows that Netinstall accepts the BOOTP requests but replies on 127.0.0.1 loopback interface:
(This is capture on two interfaces simultaneously; if I capture on Ethernet I see only requests, if on loopback - only responses)
I am running Windows 10 Pro 64-bit version 2004.
The firewall is disabled, all network interfaces but the Ethernet are disabled.
Tried running Netinstall in Windows 7 compatibility mode.
More screenshots here: https://imgur.com/a/vCBkBmM
