Does anyone know the size limit for the Configure Script option using Netinstall?
Thanks,
Mike
Means..???
I think I found the answer, 29 lines.
http://forum.mikrotik.com/viewtopic.php?f=9&t=9032&hilit=29+lines
Has anyone found a fix or way around this. I need the same install on 100+ boards and would like to save the extra step of importing a script on each one.
Thanks,
Mike
are these 3.0 boxes? You could use netinstall to ‘fetch’ a remote script and execute it in just a few lines.
I have a 63 line script I am using and it works. I have also seen it break - maybe I went over 64 lines or something. I know its very touchy : )
I install an over 80 lines firewall and other settings script at once, but in terminal inside a winbox session. Works fine and fast.
But found ´virgin´ units (usually rb133c’s) out of the box first only take 15 or so. Only the second attempt takes the big one.
rgds.
Rudy
