Netinstall doesn't see CCR1036
Hi!
I am trying make an update. On the console I see
Got IP address: 192.168.1.66
resolved mac address 00:1D:72:90:6F:29
transfer started … transfer ok, time=3.13s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation 6.39.2
Press Ctrl-Alt-Delete to abort
mac-address: D4:CA:6D:01:2C:xx
software-id: MY-soft_ID key:
MY_key ID xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx==
Waiting for installation server…
but netinstall doesn’t see my ccr router Routers/Drives window is empty
Could somebody tell me what is going on ?
I turned off remains network interfaces so the interface that rb is connected to is the only one active
The other ccr1036 is visible for netinstall, so it might be a hardware problem, I tried different versions of netinstall, the same
what is interesting , I took eeprom from ccr1012 and I soldered its on the ccr1036 mainboard then is discoverable of course as 1016 but netinstall can see my ccr. I can install soft on Nand (of course I get softid problem and ports are not visible in winbox). When I took eeprom from the other ccr1036 the situation is the same , completely invisible for \netinstall. Unfortunately I formatted Nand in the meantime so now I can only get into Routerboot nothing more.
May it be broken AR8033-Al1A chipset ? but if yes why there is any communication between netinstall an ccr ?
thanks in advance
Marcin
Did you ever find a solution to this problem, or at least the root cause? I have a similar issue with a CCR1009-8G-1S-1S+, where it will take an IP address from Netinstall, it will set up the elf image but the after trying to jump to kernel code it will simply stop. After that it transmits no packets at all, there’s no double-beep, the serial console shows nothing but it will auto-negotiate a port if you plug a cable in.
