To reinstall RouterOs at Routerboard 532A and 112 using
netinstall.exe ver 2.9.38,39,40 and 3.0beta7
routeros-rb500.npk ver 2.9.38,39,40 and 3.0beta7
I have this error: FATAL ERROR: bad network connection
at serial console i read:
RouterBOOT booter 2.7
RouterBoard XXX
CPU frequency: XXX MHz
Memory size: XX MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol… OK
Got IP address: 10.8.4.51
resolved mac address 00:00:39:BE:0C:8D
transfer started … transfer ok, time=1.14s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
Try deactivating all network interfaces on your Windows machine, but the one over which you connect to your router. Also deactivate interfaces from VMware or the like.
Netinstall sometimes has a hard time on multi-interface-cards from my experience.
switch on the RouterBOARD, hit any key to enter to the RouterBOOT;
click ‘g’ - upgrade firmware;
select ‘s’ - upgrade firmware over serial port (use option Send File from
HyperTerminal program), use Xmodem protocol.
Firmware file is available for download here, http://routerboard.com/files/rb-2.18/rc32434-2.18.fwf
