Netinstall haP ac lite
Today I tried netinstalling on a haP ac lite as I had previously done with a haP lite and found that after installing wlan2 (5GHz) was gone and the script didn’t work, so I did it again but this time applying default config instead. Still didn’t work so I took a look at the packages and it appears the when netinstalling it applies wireless-fp and not cm2 so a quick disable and enable showed wlan2 again. Is there a way to netinstall and have it wireless-cm2 instead? I tried this using routeros 6.33.5 and 6.34.2.
Just so others who may encounter this know, Mikrotik Support says:
Sorry, but unfortunately it is not possible at the moment. We will soon get rid of
wireless-fp (6.36) and then you should not experience problem like this any more.
Just have to wait for RouterOS 6.36…
