HaQs
1
Hi.
Can I flash ROS image on RB with netinstall without using the RS232 to configure boot from ethernet ?
Sometimes Happen to damage when updating the ROS from the WLAN.
Alternatively, is there any option to change RB booting to: once boot from ethernet after boot from NAND? or something like that without RS232?
HaQs
2
There is no such option?
There is a chance to add this option to ROS bootloader: If the long hold down the reset (10 sec) then RB boot from ethernet
fewi
3
The available options are:
- ethernet
flash-boot
flash-boot-once-then-nand
nand-if-fail-then-ethernet
nand-only
try-ethernet-once-then-nand
I normally get it by starting net-install and holding reset while power cycling then it net-boots…
