Hi all!
I’ve got some serious problem.
I got a second handy RB112 and just downgraded from RouterOS 5.4 to 2.9.51 via netinstall.
It worked, but I’ve got this message in serial terminal:
ERROR: installation of routeros-rb500-2.9.51 failed: broken package
Netinstall tool didn’t showed anything. I’ve tried this several time, with the same package, from different sources..but not that is my problem anyway (it seems to working good).
While updating, the software-id is XXXX-XXXX, from terminal and netinstall tool also. After reboot, it changed to XXXX-YYY, but the key remained the same. Of course, these don’t match to each other, so RouterOS says, I’ve got less then 24H to get a proper license.
Because I DO have a proper license, but the software-id is changing after netinstall every time, to XXXX-YYY.
What can I do? ![]()
Mod: according to this, this issue about the 7 vs. 8 symbol ID. 2.9.51 only support 7 symbol ID. Is there any way, to convert my key back to 7 symbol ID? Just as 7 symbol keys were converted to 8 symbol.
Mod2: managed to recover, from flash backup ![]()
Thx ![]()
