Netinstall on RB150: Broken package
I had a spare RouterBoard (I believe a RB150) that I wanted to upgrade before putting it on my test bench as an endpoint device. I used Netinstall to try the upgrade path from 2.x (I didn't record the installed version number) -> 3.3 -> 4.6. The first run of Netinstall formatted and then failed when installing 3.3. Now I've got a brick and am unable to install any version.
I started with mipsle from the torrent file, then tried all packages and then combined packages from multiple download sites. I've tried two sites in the US, Latvia, China and Australia.
Are there older pieces of hardware that are incompatible with the new releases? Can I get an older release to enable this again or is it a lost cause?
I've seen multiple posts about broken packages at the beginning of the year, but this was reported fixed.
RouterBOOT booter 2.8
RouterBoard miniROUTER
CPU frequency: 175 MHz
Memory size: 32 MB
Formatting disk..........
ERROR: installation of routeros-mipsle-3.30 failed: broken package
WARNING: package system-3.30 onuninstall script failed
ERROR: installation of system-4.6 failed: broken package
WARNING: package system-4.6 onuninstall script failed
ERROR: installation of system-3.30 failed: broken package
ERROR: can not install advanced-tools-3.30: system-3.30 is not installed, but is required
[?25l
installing system-2.9.51 [ ]
[?25h[?25l
[?25hERROR: installation of system-2.9.51 failed: broken package
WARNING: package system-2.9.51 onuninstall script failed
ERROR: can not install routerboard-2.9.51: system-2.9.51 is not installed, but is required
