Hi
So I haven’t used my Mikrotik in a while. Since then the network changed and I can’t just hook it up because it would have clashed. So I thought the thing to do was to reset it to factory and re-install.
So I did and now when it boots it won’t allow me to connect to any Ethernet ports and shows no WiFi. The little screen comes up and works. I have also tried NetInstall and pulled the newest RouterOS on it. That worked fine but it still has the same behaviour.
What’s going on??? Is it bricked? Am I missing something here? I don’t have a serial cable for it (I have a FTDI tho) so can’t see the console.
Hope someone can help!
Cheers Oliver
