I have quite a problem in my hands, i have a friends RB532 which lost it’s PoE Eth1 port during a lightning storm.
It powers up, i can connect to it using serial, and access the menus but i allways get this message:
RouterBOOT booter 2.18
RouterBoard 532
CPU frequency: 399 MHz
Memory size: 32 MB
Press any key within 5 seconds to enter setup…
kernel not found
trying bootp protocol… failed
kernel loading failed
Givin this, i can’t get Netinstall to find the RB500 (probably due to the fried Eth1 PoE port), is there a way to copy the files needed via serial cable ?
I could realy use some help on this one, thanks for your attention.
I think there is a way to install it by RS232. I used it in the RB133 same way damaged. Plug your RS232, download terraterm, follow mt menu and the white rabbit.
The RB532 i have is useless as it is, so i’m willing to test anything at all…
COELPL, can you please place some more detailed info on how you did it on you RB133, maybe the process is the same or similar, either case it will be very helpfull.
Thanks in advanced.
Best regards,
Paulo Brinca.
PS.: By the way (and this is for the Administration) there where 3 more entries on this topic that went missing, one of them was mine…
It’s not very polite to delete messages that contain no harmfull language, or any kind of insult…
