Been stuck trying to un-brick a CAP XL ac, and have not got netinstall to work.
Most specifically, netinstall hangs having done this:
[root@netinstall ~]# ./netinstall-cli -a 192.168.88.1 routeros-7.11.2-arm.npk
Version: 7.12rc1(2023-10-05 06:32:41)
Interface Mask: 255.255.255.0
Using Client IP: 192.168.88.1
Using Server IP: 192.168.88.2
Starting PXE server
Waiting for RouterBOARD...
I have a dedicated virtual machine running Rocky9 that is installed for the sole purpose of netinstall.
The network is configured as follows:
[root@netinstall ~]# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 52:54:00:d7:28:34 brd ff:ff:ff:ff:ff:ff
inet 192.168.88.2/24 brd 192.168.88.255 scope global noprefixroute enp1s0
inet6 fe80::5054:ff:fed7:2834/64 scope link
3: enp7s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 52:54:00:6d:44:7b brd ff:ff:ff:ff:ff:ff
The CAP XL ac is connected through an RB5009. The netinstall virtual machine sees bootp traffic as below. I have confirmed that the MAC address matches the MAC address printed on the outside of the bricked device.
16:16:06.489445 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
16:16:06.689581 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
16:16:06.889717 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
16:16:07.089877 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
16:16:07.290036 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
16:16:07.490184 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 18:fd:74:3e:d7:b0 (oui Unknown), length 300
Looking at the netinstall process, it appears to have forked itself, one process listens on port “commplex-main”, the second listens on “bootps” and “tftp”:
[root@netinstall ~]# ps -auxwww | grep netinstall
root 48231 0.0 0.0 44088 208 ttyS0 S 17:16 0:00 ./netinstall-cli -a 192.168.88.1 routeros-7.11.2-arm.npk
root 48232 0.0 0.0 44088 44 ttyS0 S 17:16 0:00 ./netinstall-cli -a 192.168.88.1 routeros-7.11.2-arm.npk
root 48238 0.0 0.0 6408 2188 ttyS0 S+ 17:16 0:00 grep --color=auto netinstall
[root@netinstall ~]# lsof -p 48231
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
netinstal 48231 root cwd DIR 253,0 4096 4194434 /root
netinstal 48231 root rtd DIR 253,0 235 128 /
netinstal 48231 root txt REG 253,0 44954972 4207421 /root/netinstall-cli
netinstal 48231 root 0u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48231 root 1u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48231 root 2u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48231 root 3u IPv4 75332 0t0 UDP *:commplex-main
[root@netinstall ~]# lsof -p 48232
netinstal 48232 root cwd DIR 253,0 4096 4194434 /root
netinstal 48232 root rtd DIR 253,0 235 128 /
netinstal 48232 root txt REG 253,0 44954972 4207421 /root/netinstall-cli
netinstal 48232 root 0u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48232 root 1u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48232 root 2u CHR 4,64 0t0 94 /dev/ttyS0
netinstal 48232 root 3u IPv4 76463 0t0 UDP *:bootps
netinstal 48232 root 4u IPv4 76465 0t0 UDP *:tftp
There is no firewall:
[root@netinstall ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Strace shows we’re stuck at this point:
sendto(4, [{nlmsg_len=20, nlmsg_type=RTM_GETADDR, nlmsg_flags=NLM_F_REQUEST|NLM_F_DUMP, nlmsg_seq=2, nlmsg_pid=0}, {ifa_family=AF_UNSPEC, ...}], 20, 0, NULL, 0) = 20
recvfrom(4, [[{nlmsg_len=76, nlmsg_type=RTM_NEWADDR, nlmsg_flags=NLM_F_MULTI, nlmsg_seq=2, nlmsg_pid=48248}, {ifa_family=AF_INET, ifa_prefixlen=8, ifa_flags=IFA_F_PERMANENT, ifa_scope=RT_SCOPE_HOST, ifa_index=if_nametoindex("lo")}, [[{nla_len=8, nla_type=IFA_ADDRESS}, inet_addr("127.0.0.1")], [{nla_len=8, nla_type=IFA_LOCAL}, inet_addr("127.0.0.1")], [{nla_len=7, nla_type=IFA_LABEL}, "lo"], [{nla_len=8, nla_type=IFA_FLAGS}, IFA_F_PERMANENT], [{nla_len=20, nla_type=IFA_CACHEINFO}, {ifa_prefered=4294967295, ifa_valid=4294967295, cstamp=130, tstamp=130}]]], [{nlmsg_len=88, nlmsg_type=RTM_NEWADDR, nlmsg_flags=NLM_F_MULTI, nlmsg_seq=2, nlmsg_pid=48248}, {ifa_family=AF_INET, ifa_prefixlen=24, ifa_flags=IFA_F_PERMANENT, ifa_scope=RT_SCOPE_UNIVERSE, ifa_index=if_nametoindex("enp1s0")}, [[{nla_len=8, nla_type=IFA_ADDRESS}, inet_addr("192.168.88.2")], [{nla_len=8, nla_type=IFA_LOCAL}, inet_addr("192.168.88.2")], [{nla_len=8, nla_type=IFA_BROADCAST}, inet_addr("192.168.88.255")], [{nla_len=11, nla_type=IFA_LABEL}, "enp1s0"], [{nla_len=8, nla_type=IFA_FLAGS}, IFA_F_PERMANENT|IFA_F_NOPREFIXROUTE], [{nla_len=20, nla_type=IFA_CACHEINFO}, {ifa_prefered=4294967295, ifa_valid=4294967295, cstamp=545, tstamp=545}]]]], 8192, MSG_DONTWAIT, NULL, NULL) = 164
recvfrom(4, [[{nlmsg_len=72, nlmsg_type=RTM_NEWADDR, nlmsg_flags=NLM_F_MULTI, nlmsg_seq=2, nlmsg_pid=48248}, {ifa_family=AF_INET6, ifa_prefixlen=128, ifa_flags=IFA_F_PERMANENT, ifa_scope=RT_SCOPE_HOST, ifa_index=if_nametoindex("lo")}, [[{nla_len=20, nla_type=IFA_ADDRESS}, inet_pton(AF_INET6, "::1")], [{nla_len=20, nla_type=IFA_CACHEINFO}, {ifa_prefered=4294967295, ifa_valid=4294967295, cstamp=130, tstamp=130}], [{nla_len=8, nla_type=IFA_FLAGS}, IFA_F_PERMANENT]]], [{nlmsg_len=72, nlmsg_type=RTM_NEWADDR, nlmsg_flags=NLM_F_MULTI, nlmsg_seq=2, nlmsg_pid=48248}, {ifa_family=AF_INET6, ifa_prefixlen=64, ifa_flags=IFA_F_PERMANENT, ifa_scope=RT_SCOPE_LINK, ifa_index=if_nametoindex("enp1s0")}, [[{nla_len=20, nla_type=IFA_ADDRESS}, inet_pton(AF_INET6, "fe80::5054:ff:fed7:2834")], [{nla_len=20, nla_type=IFA_CACHEINFO}, {ifa_prefered=4294967295, ifa_valid=4294967295, cstamp=545, tstamp=545}], [{nla_len=8, nla_type=IFA_FLAGS}, IFA_F_PERMANENT]]]], 8192, MSG_DONTWAIT, NULL, NULL) = 144
recvfrom(4, [{nlmsg_len=20, nlmsg_type=NLMSG_DONE, nlmsg_flags=NLM_F_MULTI, nlmsg_seq=2, nlmsg_pid=48248}, 0], 8192, MSG_DONTWAIT, NULL, NULL) = 20
close(4) = 0
setsockopt(3, SOL_SOCKET, SO_BINDTODEVICE, "enp1s0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 32) = 0
writev(1, [{iov_base="Waiting for RouterBOARD...", iov_len=26}, {iov_base="\n", iov_len=1}], 2Waiting for RouterBOARD...
) = 27
recvfrom(3,
Am I correct in understanding that seeing the bootp incoming traffic means that the CAP XL ac is in etherboot mode, and is correctly broadcasting bootp packets?
Why does netinstall hang?
