Netinstall Stuck on Sending Offer
Hi All,
I’ve needed to install new default scripts in some of my routerboard 951G units. I used v6.3 of Netinstall to upload v6.15 of the software along with my config script. That was fine. I then noticed an error in the script which I fixed and tried to upload v6.15 of the software again along with the new script. At this point the status bar just says “Sending Offer” for a few seconds and then stops, having done nothing.
I’ve tried upgrading the router to 6.30.2 using winbox. I’ve tried without the config scripts. I’ve tried checking the “use default config” box. I don’t know what is causing this problem. Any thoughts?
Thanks,
CD
