I’m getting broken package errors when i try to netinstall
ERROR: installation of routeros-mipsbe-4.11 failed: broken package
looks like it gets 70% of the way there, I also tried to install just the system packages from 3.30 and 4.11, when I do that with netinstall on the gui it thinks the installation worked but on the serial console i see it failed.
Waiting for installation server...
Found server at 00:01:6C:0C:BE:56
Formatting disk..........
ERROR: installation of system-4.11 failed: broken package
Writing configuration...
Software installed.
Press ENTER to reboot
I’ve tried first reformatting the NAND from the routerboot menu, combined packages for 3.30, 4.11 and 5.0 beta6, just the system packages for 3.30 and 4.11
Is there a way to get more details on why it failed to install?
