Netinstall transfer fails on some RouterBoards
What exactly does it mean (beyond “something isn’t working”) when, running netinstall, after the serial console displays “transfer started”, the usual line of dots ‘.’ start printing stars ‘*’ instead? (And continues to print stars until it gives up and boots from flash; see log output.)
As for clearing the condition, the following do not solve the problem:
  • re-launch netinstall (v6.6)
  • run older versions of netinstall (v5.17, v4.3)
  • run netinstall (all three versions) as administrator
  • reboot the PC and try all of the above again
In the most recent case, I was able to get a board working with ‘netinstall’ again only be re-flashing the boot code via XMODEM. What gives?! Two years of my test bench running netinstall flawlessly, and suddenly I’m running into boards that have this problem, either intermittently or consistently.
RouterBOOT booter 2.18
RouterBoard 532
CPU frequency: 264 MHz
  Memory size:  32 MB
Press any key within 2 seconds to enter setup
RouterBOOT-2.18
What do you want to configure?
   d - boot delay
   k - boot key
   s - serial console
   o - boot device
   u - cpu mode
   f - try cpu frequency
   c - keep cpu frequency
   r - reset booter configuration
   e - format nand
   g - upgrade firmware
   i - board info
   p - boot protocol
   t - do memory testing
   x - exit setup
your choice: o - boot device
Select boot device:
   e - boot over Ethernet
 * n - boot from NAND, if fail then Ethernet
   c - boot from CompactFlash only
   1 - boot Ethernet once, then NAND
   2 - boot Ethernet once, then CompactFlash
   o - boot from NAND only
   b - boot chosen device
your choice: 1 - boot Ethernet once, then NAND
RouterBOOT-2.18
   d - boot delay
   k - boot key
   s - serial console
   o - boot device
   u - cpu mode
   e - format nand
   i - board info
   p - boot protocol
   x - exit setup
your choice: x - exit setup
writing settings to flash... OK
RouterBoard 532
  Memory size:  32 MB
Press any key within 2 seconds to enter setup..
trying bootp protocol............ OK
Got IP address: 192.168.10.86
resolved mac address C8:9C:DC:38:86:14
transfer started ....................**************************************[stars continue for several pages]************ transfer timed out
falling back to small packet size
**************************************[stars continue for several pages]*****************kernel loading failed
RouterBoard 532
  Memory size:  32 MB
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 5.24
MikroTik Login:
is router connected directly to PC or via some network. If the latter, then try to connect directly. Package transfer happen via TFTP (as in UDP) if packets go missing you get the star instead of a dot.
They are on the same subnet, but not connected directly. The odd thing is, this same setup (NIC, cat5, switch, cat5, OmniTik-UPA, cat5) has worked ~100% for the past couple years.
Thanks for explaining exactly what it means; that makes it easier to track down why it happens.
