Netinstall / Upgrade problems
Hi All,
Ive been trying to work out if I can upgrade my 2.9.10 install to 2.9.44 with netinstall. The system is installed on x86 hardware. Or if I can just login to my account on the website and purchase a new license for the same key and then just ftp the files to the system and reboot it.
I have tried to use netinstall and the PXE boot option, but even with the two systems on the same switch, the router would never get the pxe boot options from the program. In the doc’s I read that there was a .dll file which should be in the same directory as the netinstall.exe but I couldnt find this file on the website. I also tried to put the hdd in the xp machine, but it wouldnt show up as an install target.
Any pointers would be appreciated.
cheers
cwispy
