I can’t get netinstall to detect the hap-lite. I’ve followed the procedure (press reset button for 15 seconds while device is booting, wait for ACT led to turn off) but nothing happens.
btw (currently on 6.30), tried with netinstall 6.0 and 6.30
“Netinstall freezes when clicking install” - do you have other routers that work with the same steps on same Windows PC? Have you disabled Firewall, Antivirus, tried another PC?
“Netinstall doesn’t even see the hAP lite” - are you plugging the PC directly into Ether1 (first port) on the hAP lite? Did you correctly push the Reset button before applying power to the router, and keep the button Pressed until hAP lite shos up in Netinstall ?
