Netinstall
Hi Guys,
When you do a Netinstall to a MT router. Are you supposed be able to ping from your laptop to the PXE ethernet enabled setting from netinstall? I cant ping it on mine and the router is failing to see an ethernet connected .
Im netinstalling a MT 2011(10 port router) and connected on port 1 of the router.
Check this thread:
http://forum.mikrotik.com/t/netinstall-instructions/123631/1
Pay attention to info in posts 7, 11 and definitely 15.
