Hi
I have been struggling for the past two hours trying to get netinstall to talk to my CCR-1009
Following a power cut the router won’t boot (“loading kernel from nand”)
…same issue as : http://forum.mikrotik.com/t/ccr-1016-kernel-panic/79741/1
I have set up the CCR-1009 with boot to Ethernet
I activated the Boot server in Netinstall and entered an ip address within the same subnet
I keep getting “Please, check ethernet cable…”
I have tried a direct link, intermediate switch…nothing works
I have even attempted to use DHCP protocol - the router however doesn’t attempt to reach the DHCP server
I tested the same setup with an RB433 and it works perfectly
Any ideas ?
thanks
yann
