We have 5 valid IP addresses, which are being setup from ISP in our office, and my clients have access to Internet using these addresses, the point is i don’t exactly know what is the difference between Net-map and Src-nat and masquerade in NAT, as far as i know all map private IP to public IP, but which one to use and when to use? ( for now all clients are being masqueraded and everything looks fine ).
Have you need to reach services from outside (Internet) that are available within your LAN?
yes sure we have 2 web server and ftp server, our services must be visible to public…
Ok,
when you use the Netmap mode you open all ports and protocols from a public IP to a IP of your internal network like a DMZ.
ex from Wiki:
/ip firewall nat add chain=dstnat dst-address=11.11.11.0/24 \
action=netmap to-addresses=2.2.2.0/24
/ip firewall nat add chain=srcnat src-address=2.2.2.0/24 \
action=netmap to-addresses=11.11.11.0/24
When you use dst-nat you can define only ports and protocols that must be used:
/ip firewall nat add chain=dstnat dst-address=YourPublicIP action=dst-nat to-addresses=YourLANIP
something like:
/ip firewall nat add chain=dstnat action=dst-nat to-addresses=YourLANIP to-ports=21 protocol=tcp dst-address=YourPublicIP dst-port=21 log=no log-prefix="" comment="dst-nat FTP service"
Please read the wiki’s page:
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT
thx
you know, i now can get the point about what you said, but in WIKI i read these and i cant figure out the difference :
netmap - creates a static 1:1 mapping of one set of IP addresses to another one. Often used to distribute public IP addresses to hosts on private networks
src-nat - replaces source address of an IP packet to values specified by to-addresses and to-ports parameters
so what is the difference between these two? both have to-addresses and to-ports field !!
Please read the difference between source NAT and destination NAT.
If your goal is to open services from a public network to a private destination you will need to use destination NAT.
