Hi, I have a strange “problem”, I have netmap my public IPs to route them through L2TP tunnel, but when I try to do ping to this IPs, ping is unreachable… if I disable netmap rules for any IP, this IP is ping reached from outside… if enable rule ping unreachable. But my clients can use internet, it´s working now, but the only doub is about ping…
Other question, by this way I don´t need to open ports, right? All ports is opened for each IP?
add fast-forward=no name=loopback
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=proxy-arp
add name=VPN-L2TP-IPSec ranges=10.1.200.2-10.1.200.254
add name=PPTP ranges=10.1.100.2-10.1.100.254
/ppp profile
add change-tcp-mss=yes dns-server=172.16.1.1,8.8.8.8 local-address=172.16.1.1 \
name=profile-pptp only-one=yes
add local-address=10.1.200.1 name=L2TP-IPSec remote-address=VPN-L2TP-IPSec
add local-address=10.1.100.1 name=PPTP only-one=yes remote-address=PPTP
set discover-interface-list=none
/interface l2tp-server server
set enabled=yes ipsec-secret=L2TPPassword use-ipsec=yes
/interface pptp-server server
set enabled=yes
add address=borderIP interface=ether1 network=BorderNetwork
add address=xxx.xxx.xxx.xxx/24 interface=ether1 network=xxx.xxx.xxx.0
add address=uuu.uuu.uuu.uuu/24 interface=ether1 network=xxx.xxx.xxx.0
add address=zzz.zzz.zzz.zzz/24 interface=ether1 network=xxx.xxx.xxx.0
add address=yyy.yyy.yyy.yyy/24 interface=ether1 network=xxx.xxx.xxx.0
add address=192.168.254.1 interface=loopback network=192.168.254.1
add address=uuu.uuu.uuu.uuu interface=ether1 network=xxx.xxx.xxx.0
/ip arp
add address=zzz.zzz.zzz.zzz interface=ether1 mac-address=-------------
add address=yyy.yyy.yyy.yyy interface=ether1 mac-address=-------------
add address=uuu.uuu.uuu.uuu interface=ether1 mac-address=-------------
add address=xxx.xxx.xxx.xxx interface=ether1 mac-address=-------------
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1
set cache-max-ttl=1d servers=\
8.8.8.8,8.8.4.4
add action=accept chain=input comment="Allow VPN - PPTP Server" dst-port=1723 \
protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=input comment="Allow VPN - L2TP / IPSec Server" \
dst-port=1701 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input protocol=ipsec-ah
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input comment="Alow VPN traffic access & passthrough" \
src-address=10.1.100.0/24
add action=accept chain=forward src-address=10.1.100.0/24
add action=accept chain=input src-address=10.1.200.0/24
add action=accept chain=forward src-address=10.1.200.0/24
add action=masquerade chain=srcnat disabled=yes out-interface=ether1
add action=netmap chain=dstnat dst-address=xxx.xxx.xxx.xxx to-addresses=\
172.16.1.50
add action=netmap chain=srcnat src-address=172.16.1.50 to-addresses=\
xxx.xxx.xxx.xxx
add action=netmap chain=dstnat dst-address=yyy.yyy.yyy.yyy to-addresses=\
172.16.1.51
add action=netmap chain=srcnat src-address=172.16.1.51 to-addresses=\
yyy.yyy.yyy.yyy
add action=netmap chain=dstnat dst-address=zzz.zzz.zzz.zzz to-addresses=\
172.16.1.52
add action=netmap chain=srcnat src-address=172.16.1.52 to-addresses=\
zzz.zzz.zzz.zzz
add action=netmap chain=dstnat disabled=yes dst-address=uuu.uuu.uuu.uuu \
to-addresses=10.1.200.2
add action=netmap chain=srcnat disabled=yes src-address=10.1.200.2 \
to-addresses=uuu.uuu.uuu.uuu
add distance=1 gateway=111.111.111.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ppp secret
add local-address=172.16.1.1 name=xxx.xxx.xxx.xxx-! password=\
"password5" remote-address=172.16.1.50 service=pptp
add disabled=yes local-address=172.16.1.1 name=test-test password=password4 \
profile=profile-pptp remote-address=172.16.1.51 service=pptp
add local-address=172.16.1.1 name=yyy.yyy.yyy.yyy password="password3" \
add local-address=172.16.1.1 name=zzz.zzz.zzz.zzz password="password2" \
remote-address=172.16.1.52 service=pptp
add local-address=10.1.200.1 name=uuu.uuu.uuu.uuu password="pasword1" \
profile=L2TP-IPSec remote-address=10.1.200.2 service=l2tp
/system identity
set name=Border
/system logging
add disabled=yes topics=pptp
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
