blake:
Myron:
i saw the packets count in both netmap but the problem is from outside the ip xxx.xx.xxx.203 doesnt reply, i put 10.11.0.10 in laptop and i ping the xxx.xx.xxx.203 it work and reply im wondering this, can you please explain more bit blake hehe
Can you post the output of ‘/ip firewall filter export’?
I assume you have firewall rules in your forward chain. If you have a reject / drop rule at the end of your forward chain, you’ll have to add a rule explicitly allowing external traffic to access the internal, netmap host. Otherwise traffic to .203 will match the reject / drop rule and not be accessible, as you state is the case with your configuration.
/ip firewall filter add chain=forward in-interface=Ether1-WAN dst-address=10.11.0.10
The dst-address is specified as the internal IP because the packet enters the forward chain after the netmap translation has been performed from the external IP. Until you post your config I can’t tell you exactly where to place that rule.
The .203 IP is pingable from the inside of your network because your input chain likely does not prohibit access from the LAN subnet.
I’m just making some guesses based on common firewall configs. Post yours, and I could tell you for sure!
hi blake this is my currently filter rules
add action=drop chain=forward comment=rapidshare disabled=no dst-address-list=rapidshare protocol=tcp
add action=drop chain=forward comment=“yahoo messenger” disabled=yes layer7-protocol=yahoo-messenger time=
7h-12h,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment=“” disabled=yes layer7-protocol=yahoo-messenger time=13h-17h,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment=“fb block” disabled=yes dst-address-list=facebook
add action=drop chain=forward comment=“not allowed ip” disabled=yes dst-address=10.2.2.0/24 src-address=
10.11.0.25-10.11.0.200
add action=drop chain=forward comment=“” disabled=yes dst-address=10.2.2.0/24 src-address=10.12.0.2-10.12.0.254
add action=drop chain=forward comment=“” disabled=yes dst-address=10.2.2.0/24 protocol=icmp src-address=10.12.0.0/24
add action=drop chain=forward comment=“” disabled=yes dst-address=10.11.0.0/24 src-address=10.12.0.2-10.12.0.200
add action=drop chain=forward comment=“” disabled=yes dst-address=10.11.0.0/24 protocol=icmp src-address=10.12.0.0/24
add action=drop chain=forward comment=“Front 1 limited access by time” disabled=no dst-port=80 protocol=tcp src-address=
10.2.2.3 time=0s-6h,sun,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment=“front 2 office limited access by time” disabled=no dst-port=80 protocol=tcp
src-address=10.2.2.5
add action=drop chain=forward comment=“remote desktop” disabled=yes dst-port=3389 protocol=tcp time=
add action=drop chain=forward comment=worms disabled=no dst-port=135,137,139,445,5554,1068,9996,4444,43 protocol=tcp
add action=drop chain=forward comment=“” disabled=no dst-port=135-39,445,69 protocol=udp
add action=add-src-to-address-list address-list=blocked-addr address-list-timeout=52w2d chain=input comment=
“tarpit instead of drop” connection-limit=200,32 disabled=yes protocol=tcp
add action=tarpit chain=input comment=“” connection-limit=3,32 disabled=no protocol=tcp src-address-list=blocked-addr
add action=jump chain=forward comment=“SYN Flood protect” connection-state=new disabled=yes jump-target=SYN-Protect protocol=
tcp tcp-flags=syn
add action=accept chain=SYN-Protect comment=“” connection-state=new disabled=yes limit=400,5 protocol=tcp tcp-flags=syn
add action=drop chain=SYN-Protect comment=“” connection-state=new disabled=yes protocol=tcp tcp-flags=syn
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=
“Port scanners to list " disabled=no protocol=tcp psd=21,3s,3,1
“NMAP FIN Stealth scan” disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/FIN scan”
disabled=no protocol=tcp tcp-flags=fin,syn
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/RST scan”
disabled=no protocol=tcp tcp-flags=syn,rst
“FIN/PSH/URG scan” disabled=no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“ALL/ALL scan”
disabled=no protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“NMAP NULL scan”
disabled=no protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“dropping port scanners” disabled=no src-address-list=“port scanners”
add action=drop chain=input comment=“drop ssh brute forcers” disabled=no dst-port=22 protocol=tcp src-address-list=
ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=52w2d chain=input comment=”"
connection-state=new disabled=no dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input comment=“” connection-state=
new disabled=no dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input comment=“” connection-state=
new disabled=no dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input comment=“” connection-state=
add action=drop chain=input comment=“Bruteforce FTP” disabled=no dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output comment=“” content=“530 Login incorrect” disabled=no dst-limit=1/1m,9,dst-address/1m protocol=
tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output comment=“” content=
“530 Login incorrect” disabled=no protocol=tcp
add action=accept chain=forward comment=ICMP disabled=no protocol=icmp
add action=accept chain=forward comment=“chikka txt messenging” disabled=no dst-port=3128,6301 protocol=tcp
add action=accept chain=forward comment=MAIL disabled=no dst-port=25,26,143,110,465,995,2525,587 protocol=tcp
add action=accept chain=forward comment=HTTP disabled=no dst-port=80,2095 protocol=tcp
add action=accept chain=forward comment=HTTPS disabled=no dst-port=443 protocol=tcp
add action=accept chain=forward comment=FTP disabled=no dst-port=20,21 protocol=tcp
add action=accept chain=forward comment=MSN disabled=no dst-port=1863,6901-6900 protocol=tcp
add action=accept chain=forward comment=“” disabled=no dst-port=6901 protocol=udp
add action=accept chain=forward comment=“ventrillo and mumble” disabled=no dst-port=4346,64738 protocol=tcp
add action=accept chain=forward comment=“vonage " disabled=no dst-port=10000-20000 protocol=udp
add action=accept chain=forward comment=”" disabled=no dst-port=5050,5060-5063 protocol=udp
add action=accept chain=forward comment=“” disabled=no dst-port=53,8767 protocol=udp
add action=accept chain=forward comment=“” disabled=no dst-port=123 protocol=udp
add action=accept chain=forward comment=“” disabled=no dst-port=80 protocol=udp
add action=accept chain=forward comment=SSH disabled=no dst-port=22,23 protocol=tcp
add action=accept chain=forward comment=eve-online disabled=no dst-port=26000,6112 protocol=tcp
add action=accept chain=forward comment=7stones_cpanel disabled=no dst-port=2082 protocol=tcp
add action=accept chain=forward comment=wisevideo disabled=no dst-port=1935 protocol=tcp
add action=accept chain=forward comment=winbox disabled=no dst-port=8291 protocol=tcp
add action=accept chain=forward comment=mirc disabled=no dst-port=6667,6668 protocol=tcp
add action=accept chain=forward comment=“streaming server” disabled=no dst-port=8000 protocol=tcp
add action=accept chain=forward comment=“instant messenger” disabled=no dst-port=5050,5100,5000-5010 protocol=tcp
add action=accept chain=forward comment=“INCOMING Manila VPN” disabled=no protocol=tcp src-port=1723
add action=accept chain=forward comment=“” disabled=no protocol=gre
add action=accept chain=forward comment=“nano allow” disabled=no protocol=tcp src-port=1234,12345
add action=accept chain=forward comment=“ubi to outside” disabled=no dst-port=12345 protocol=tcp
add action=accept chain=forward comment=teamspeak disabled=no dst-port=9987 protocol=udp
add action=accept chain=forward comment=“google talk” disabled=no dst-port=5222,5223 protocol=tcp
add action=drop chain=forward comment=snmp disabled=no dst-port=161 protocol=udp
add action=drop chain=forward comment=“P2P block” disabled=no p2p=all-p2p
add action=drop chain=forward comment=“” disabled=no out-interface=Ether1-WAN
thanks for help blake
