Dear all,
I’m hoping you can provide me with some recommendations.
Assume the following situation: a (remote-controlled) robot has to provide the operator with data from sensors mounted to it. The operator is in a fixed location, and we can assume maximum distances of 300 meters as well as Line-Of-Sight communications, with few if any obstacles.
Robot operation itself is accomplished using a 2,4 GHz WLAN system (tried and trusted); no problem here.
The problem is that the sensors attached to the robot produce a LOT of data. In consequence, I need a stable link capable of carrying about 1GBit (more would be better) from the robot to the OCU (Operator Control Unit). There will be some traffic from the OCU to the sensors as well. While negligible in bandwidth, I do require this broadband link to be bi-directional.
I am hoping that two NetMetal 5 units would be an adequate solution to my problem and have purchased two units.
I have added RB11e-HacD cards to both of them, to supplement the on-board 802.11ac WLAN for an (eventually) aggregated setup.
In my initial tests (using just the internal WLAN), I have outfitted both units with omnidirectional 5GHz Antennas and configured them to my best knowledge (80 MHz Bandwith Ceee), WLAN AC only, 3 chains and all MCS-Modes enabled. The units are approximately 15 meters apart. The Antennas of both units are currently aligned in parallel. (Chain 1: -45°, Chain 2: 90° (vertical), Chain 3: +45°)
I have then proceeded to run some bandwidth tests (UDP packets of varying sizes) using the built-in tools (AP = Server, Station = Client).
Throughput as reported by the client can go as high as 300 MBit, but I’m unfortunately not seeing anything higher. CPU-Load seems to top out at approximately 50%.
So far, I have tried configurations 802.11 and NV2, with comparable results. Setting all Antennas to 90° didn’t change anything.
Could anyone make some suggestions as to what else may need to get adjusted in order to get more usable bandwidth or am I actually topping out the bandwidth server?
Thanks!
Colin
