Dear Mikrotik guys,
I need the best ptp configuration for Netmetal 5 RB922UAGS-5HPacD-NM Radio with 30db dish. All I need 100Mbps TCP throughput. I’ve tried many ways but no luck. The maximum I can get is 40Mbps MAX. It would be so helpful if you guys guide me the best way to configure those Radio. Now I’m using Ubnt rocket m5 instead of netmetal5. Rocket is giving 50Mbps TCP at 30mhz but I need 100Mbps or more if possible with netmetal5.
Thanks.
Sent from my iPhone using Tapatalk
It is better to show us what you did and we can suggest changes.
