Netmetal 5 Wrong Freq in STATUS vs Choosen one
I just set up a link, and I choose, 20/40/80 eeeC on freq 5825 Mhz. But under the STATUS tab on the client side and AP side ( Under Wireless Interface ), it says 5240/20-eeeC/AC
I can change the channel to anything else, and all I have seen is 5200, and 5240. but never the one I pick..
Why is this not connecting on the frequency I choose?
The AP is set to the choosen freq, the client is on AUTO, so it follows the AP if I need to change the freq.
WIERD!
MAC addresses and SSID ID and Key names removed for security. below you will see that it is set to 5825,
0 R name=“IFACENAME” mtu=1500 mac-address=00:00:00:00:00:00 arp=enabled
interface-type=Atheros AR9888 mode=ap-bridge ssid=“MYSSIDREMOVED”
frequency=5825 band=5ghz-onlyac channel-width=20/40/80mhz-eeeC
scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
wds-mode=dynamic wds-default-bridge=Bridge - Private wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=yes
security-profile=MYKEYSNAME compression=no
