NetMetal AC2 enclosure - Rj45 feed-thru?
Does anyone have experience with the NetMetal type enclosures and finding out-of-the-box compatible RJ-45 Feed-thru Glands that Fit??
I bought some, but I would need to use a step drill to slightly enlarge the bottom case hole. As well as reshape the sealing washer to make a secure fitment.
Anyone?
I not have experience with NetMetal enclosures, but yes with BaseBox/NetBox enclosures and works perfect.
Regards.
Could you tell me what brand or provide me with web link to the feed-thru connectors you used?
BaseBox 2 and BaseBox 5.
Regards.
Understood. Those are same enclosure as The NetMetal. but there are rubber grommets at bottom where you slice and slide ethernet cable through.
I’m asking if anyone has modified and instead used a better design and attached RJ47 feed-thru gland connectors
IE: https://www.lairdconnect.com/rf-antennas/antenna-accessories/rj45-feed-thru
