netmetal ac2 +
Hello
I need to cover a shed 52m x 11m with wifi
I’d like to cover it in 5ghz but i’d prefer dual band
I’ve ethernet cables in the center(more or less) of the building.
I’d like to ask you if a single netmetal ac2 with 2 HGO-antenna-OUT can cover the entire building(≃20-30 meters).
I can place the netmetal so no wall is in the way and 3m of height. Near perimetral walls you can find metal machinery and metal sheets can be in the way on ground level(can they reflect waves and create noise?)
I need to connect 4-5 PCs (no big file trasfers) and 3-4 cameras . Low ping not needed.
I’d like the netmetal cause there is humidity and is metal case.
Thank you in advance for all the help you can give me!!!
help me plz :slight_smile:
Yes. You should not be problems.
Regards.
Thank you!!!
