NETMETAL5 CONFIGURE
HOW TO CONFIGURE NETMETAL5 AND HOW TO
INCREASE TRANSFER BANDWIDTH
PLEASE UPDATE
What do you expect as answer?
I guess he needs a configuration guide.
This antennas come with dual chain for better performance.
I actually have RB921UAGS-5SHPacT with mANT30 .
I have noticed that only channel1 is being used, when I disconned the channel2 cable it does not make any difference.
Any help would be appreciated
:slight_smile:
Have you switched the second chain on? Take care not to switch it on when no antenna is attached because you can burn out the amplifier. If you already have not…
