Bear in mind you’re using the ends of useable frequencies, where the antenna will provide less gain. What signal do you get if you use a channel between 5400-5700 for a moment?
I believe I have done the testing in that freq. range, but signal-strength-levels get worst. I have also done a freq. usage those where the results.(attached)
This might sound wierd… but set your antenna gain to 0.
I have found this setting to allow for the radios to push out the most power (within safe limits). This then allows for better signal strength.
Let me know what your findings are. I’m getting 130mb+ with this setting over a 17km link. I think I should be getting more as there is only water in between the two links and both radios are almost 40ft off the ground.
Ok, I can try this when getting back to those links - but how is this possible ? On the other hand, since this link is located in a very rural place, power limits are not a problem - we can use maximum power possible
