NetMetal5 worst than ANT5?! [Solved]
Dear all,
I have been using Mikrotik QRT-5 5Ghz 23dbi AP/Backbone/CPE 1000mW Dual-Chain RB911G-5HPnD-QRT for a 3Km P2P link for a while.
I decided to purchase
Mikrotik mANT30 PA Parabolic Dual-Chain Dish Antenna 5GHz 30dBi MTAD-5G-30D3-PA with NetMetal RB921UAGS-5SHPacT
It seams than whatever I do (settings and alignment) the signal quality does not improve at all.
Anyone can provide me a guide on how to setup P2P dual chain with NetMetal5?
Regards
Whats your signal levels with QRt5 and now?
Dear,
I forgot to replace the power converter.
I have just noticed they had different amp.
Now the NetMetal5 is working just fine. I get 1ms-2ms pings with no packet loss :slight_smile:
Regards
