NetPower 16P POE-out issue: POE-out UP with POE-out disabled?
Hi
I have a new NetPower 16P on my tower and I have issues with the POE-out.
I have 4 IsoStation 5AC connected and two NanoStation Loco M5.
I have issues with the POE-out function because, if I setup the POE-out as Auto mode, the router doesn't dettect the devices. If I setup in forced mode, the devices starts and, the strange part: If I setup the POE mode as OFF, the devices turns on!.... I mean, the POE-out disabled must to disable the POE out but In my case, the attached device turns on!.
In another port, I have an IsoStation 5AC: If I turn on the forced poe mode, the port goes down with the warning "poe-out overload".
In another port, I have another IsoStation that I know that it's OK and, if I turn on (in forced mode), the port goes down with the same warning.
Is it possible that one of my devices is short-circuited even though it's working? Could there be any problems if there are crossover and straight-through Ethernet cables?
All the cables have 5 meters.
I'm on the ROS7.22.2
Please open a support ticket at Log into Atlassian - Support or send an email to support@mikrotik.com, and attach a fresh supout.rif file so we can analyze it.
Thanks for your reply.
I created the SUP-216929 ticket.
I have had crossover cables cause me issues with poe in the past, I never investigated why (small poe switch refused to work), I think I replaced the switch with a different one which worked ok, and later found the cables were crossover.
