netPower Lite 8 Netinstall RouterOS
Hi all, Im trying to install RouterOS on the netPower Lite 8 instead of the default SwitchOS. The unit doesnt seem to boot into NetInstall mode? I have pressed and hold the reset button for 20 seconds before applying power to the unit. The netPower Lite 8 never connects to the NetInstall app (Net booting / Boot Server Enabled etc). I have followed all available guides. From what I have read the netPower reset lamp is not behaving as it should when entering NetInstall state. Is this not possible on this model?
Thanks // J
Well, it comes NOT with ROS, not even with SWOS, it comes with SWOS lite.
No way you can install ROS on it as the product code hints:
CSS610-8P-2S+OUT
it is a CSS device, so a "pure" switch, not a switch/router like CRS devices.
Netinstall is defined as:
Netinstall is a tool for installing and reinstalling MikroTik devices running RouterOS.
Ok, thank you for the info, I thought there was only a SWOS version and not SWOS and SWOS Lite. That explains it. Thanks // J
Yep, but it doesn't make a difference, there are mainly three kinds of devices:
  1. pure switches that can run only SwOS or SwOS lite (typically CSS) whether they run SwOS or SwOs lite depends on the model and CANNOT be changed
  2. pure routers (and access points, etc.) that can run only RouterOS
  3. switches with router functions that can dual boot and run both SwOS or RouterOS (typically CRS)
