Trying to understand the total PoE out budget of the Netpower 16 if you’re only using 48V. The specs say: 2.8A (18V-30V) & 1.4A (48V-57V) x2 A. Does this mean there are 2 48V banks, each capable of 1.4A? Or is it 1 24V bank and 1 48V bank?
Thanks,
Todd
Σ(ether1..ether8) 1,4A@48V
Σ(ether9..ether16) 1,4A@48V
bu each single port MAX 0,6A@48V (~29W@48V or ~34W@57V)
For example, on one bank you can have 0,35A@48V on 4 ports, and 0,7A@24V on the others 4.
Thanks so much! This is what I thought, but wanted to make sure before deploying.
