is it possible to combine the Netwatch tool with SNMP monitoring?
What I want to do is to ping an IP address and have the result (host is reachable or not reachable) be written into an SNMP oid, so I can monitor it.
Is there a way to do that or maybe an even better solution?
Thanks!
Jotne
2
I would think its better to use syslog for this.
In a script, run the ping test, if it fail, send a syslog to a monitoring system.
Have a look at my Syslog → Splunk post linked in my signature.
Thanks for your quick response!
Yes, syslog would definitively be a proper solution, also e-mail came to mind, but the problem is it needs to be SNMP …
