Netwatch down script can't email
I use the script below and I notice that when Netwatch runs it’s “Down” script and tries to send the notification email, it fails due to a “timeout.” I understand that it can’t send an email if the connection is down, but I’m wondering what the solution is for getting notified (via email) that a there was a Netwatch down condition at xx:xx:xx time?
Note: If the status goes down and back up quickly (within a couple of seconds, I’m guessing), the script works fine (i.e., the email is sent). So, it is only those times when the connection is down and stays down while the script is trying to send the email that this problem occurs.
DOWN:
/system
:local cdate [clock get date]
:local yyyy  [:pick $cdate 0  4]
:local MM    [:pick $cdate 5  7]
:local dd    [:pick $cdate 8 10]
:local identitydate "$[identity get name]_$yyyy-$MM-$dd"
:local identity "$[identity get name]"
/tool netwatch
:local Host $host
:local Status [get [find where host="$Host"] status]
:local Interval [get [find where host="$Host"] interval]
:log info "script=netwatch watch_host=$Host comment=\"$Comment\" status=$Status interval=$Interval"
:tool e-mail send to=joseph@xxxx.com subject="$identity $Status" body=( "$Status $Host $identitydate" )
if there is no internet the email cannot be sent. The solution would be a backup connection
Send email on status up instead of on status down.
When go down memorize the datetime in a global variable,
when up send mail with the global variable value
Fantastic solution!
Will attempt to create.
Thank you.
I’m batting around .500 (my usual), which in baseball is fantastic, but in programming, not so much…
Here’s my down script:
/system
/tool netwatch
:local Host $host
:global globalstoreddown "$identitydate_Down_$Status"
Here’s my up script:
/system
/tool netwatch
:local Host $host
:if ([:len [$globalstoreddown]] > 1) do={
:tool e-mail send to=joseph@xxxx.com subject="$identity Previously Netwatch Down" body=( "$globalstoreddown" )
I confirmed that globalstoreddown gets created by the down script with
:log info $globalstoreddown
But the up script does not send the email in the line:
:if([:len [$globalstoreddown] > 1)
Also, the idea was that an email would be send that includes not just the date but the time it went down (and the time it went up).
Thanks!
