Netwatch Enable/Disable
Hello:
I am trying (so far unsuccessfully) to write a script which will disable ( even modify or delete) a netwatch monitor. So far I have only been able to add. Is this going to be possible, if so how?
John Smids
Onatrio Canada
Hello
I don’t know if this will help anyone else, but I have solved my own problem. I named the netwatch that I was trying to enable/disable (test).
/tool netwatch disable “test”.
john smids
