I’m sure this is easy, but I’m at a loss… Trying to configure netwatch to change default route when ping to a specific IP fails.
I thought this would be the correct command but apparently not
/ip route set [/ip route find dst 0.0.0.0] gateway 172.16.0.2
And the MT returns
numbers:
It is looking for the item number as related to the routing table, but I thought the point of the find command was to avoid referencing ‘static’ numbers ?
If I enter the number that is the default route (7) it works but Where would I put that in the command line, and should it be required ??
