Good morning everyone. I need to monitor some Mikrotik ATL devices, connected to my main router via Wireguard. With netwatch I created a rule that checks the reachability of the wireguard IP every 3 minutes, if the status changes it sends me an email.
The problem is that on some sites this status changes several times in a few minutes, therefore I receive dozens of down/up down/up emails, even if in reality the ATL device does not really lose the connection, since it continues to be reachable. It may be that it has a slight packet loss…
I tried to set thr. loss percent: 90.0 and thr. loss count: 50 but the situation has not improved.
Do you have any ideas to solve it?
I would like the system to try two or three times, and if all the times were negative it would send me the email, otherwise no.
Could I do this with TheDude? Or does not even Dude have this function?
Thanks to everyone
Then show off your netwatch configuration. We don’t see it.
add comment="Script ATL LTE18" disabled=no down-script=":log error \"ATL18 is DOWN\"; \r\
\n/tool e-mail send to=\"***ale@***ons.it\" subject=\"ATL LTE18 is DOWN at \$[/system clock get time]\" from=\"\$[/system identity get name] \
\"\r\
\n" host=10.100.90.106 http-codes="" ignore-initial-down=yes ignore-initial-up=yes \
interval=30m name="ATL18" test-script="" thr-loss-count=50 \
thr-loss-percent=90% type=icmp up-script=":log info \"ATL18 is UP\"; \
\r\
\n /tool e-mail send to=\"****le@***ons.it\" subject=\"ATL LTE18 is UP at \$[/system clock get time]\" from=\"\$[/system identity get name] \"\
According to your export the interval is 30m (not “every 3 minutes” as claimed in original post). But this is not your problem.
I would start over new. Or at least remove “thr-loss-percent=90%” and “thr-loss-count=50”. The defaults are way more tolerant.
thr-loss-percent (Default: 85.0%) Fail threshold for loss-percent
thr-loss-count (Default: 4294967295(max))
I don’t know about your connection to the wireguard device (how stable it is, how fast, how reliable, etc.), but keep in mind these defaults for the ICMP probe: https://help.mikrotik.com/docs/spaces/ROS/pages/8323208/Netwatch#Netwatch-icmp
Maybe it is your “thr-avg” exceeding the default 100ms and this is your issue. I guess you need to troubleshoot this step by step. Do manual pinging an see how it behaves. Then adjust netwatch ICMP probe options.
You can see which threshold gets breached, if you add Netwatch logging topic.
Thanks for your reply. How netwatch logging do you mean this?
Thank you
Simone
You are right! When doing single pings, sometimes the thr-avg reaches values of 240-370 ms, for this reason netwatch triggers it as down.
I removed all the manual values previously set and set a manual thr-avg of 700 ms. A threshold much higher than the maximum recorded in these tests, and I set the interval again every 3 minutes (I had set it to 30 minutes to avoid being inundated with emails)
Thank you
By logging I meant “/system logging add topics=netwatch”, in log you will be able to see which values were OK and which ones failed, if there are any.
