NetWatch Ipsec or Script
Hello!
We have a lot of Ipsec tunnel connected to remote Mikrotik, each Ipsec point to a separate VLAN on the main router.
We already used net watch to ping remote router and run script to change IP for the dynamic remote location when change occurs.
Now we have a bunch of new remote router to connect, but a couple have same subnet.
How can I run script to ping remote router via is VLAN to be sure its running?
I dont think its possible via netwatch to specify the from adress?
Any advice will be appreciate!
