Netwatch issue
I set up netwatch on my RB750GL successfully.
But I notice it works only if dsl-modem turns off.
So whenever modem loses dsl-alignment or internet connection I cannot know anything.
Why does this happen?
Is there a way to “watch” even those parameters?
thanks
in case u r using for failover :
/ip route add dst-address=8.8.4.4 gateway=FISRT MODEM IP
/ip route add dst-address=4.2.2.2 gateway=SECOND MODEM IP
then you should watch 8.8.4.4 and 4.2.2.2 and …
two modems? I’m not using failover
my rb750gl has to “watch” only one modem
would you please give me more information ?
why you use netwatch ? …
The two modems have to be in the same ip network, correct?
i can not get clear about what you gonna do , but
im thinking your problem is you are watching your modem ip (for example 192.168.1.1) instead of something like 8.8.8.8.
