Netwatch not sending emails
Model: rb750r2
RouterOS: 6.49.8
Hey,
I’ve got the attached config used to failover between 2 WANs on ether1 and ether5. The failover works, but the netwatch doesn’t send emails when connection’s down and when it comes back on (mail credentials are good).
Any ideas?
add admin-mac=6C:3B:6B:16:FB:E9 auto-mac=no comment=\
    "created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=\
    6C:3B:6B:16:FB:E8 name=ether1-gateway
set [ find default-name=ether2 ] advertise=\
    6C:3B:6B:16:FB:E9
set [ find default-name=ether3 ] advertise=\
    6C:3B:6B:16:FB:EA
set [ find default-name=ether4 ] advertise=\
    6C:3B:6B:16:FB:EB
set [ find default-name=ether5 ] advertise=\
    6C:3B:6B:16:FB:EC name=ether5-gateway
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
add name=default-dhcp ranges=10.9.10.10-10.9.10.80
add address-pool=default-dhcp authoritative=after-2sec-delay disabled=no \
    interface=bridge1 name=defconf
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
set discover-interface-list=discover
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add interface=ether1-gateway list=WAN
add address=10.9.10.1/24 comment=defconf interface=bridge1 network=10.9.10.0
add address=192.168.7.2/24 interface=ether1-gateway network=192.168.7.0
add address=192.168.8.2/24 comment=3G interface=ether5-gateway network=\
    192.168.8.0
add address=10.9.10.0/24 comment=defconf gateway=10.9.10.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.9.10.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=input comment="wan ssh" dst-port=6222 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" \
    in-interface=ether1-gateway
add action=drop chain=input comment="defconf: drop all from WAN2" \
    in-interface=ether5-gateway
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1-gateway
    "defconf:  drop all from WAN2 not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether5-gateway
add action=drop chain=forward comment="default configuration" \
    connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add action=drop chain=forward comment="default configuration WAN2" \
    ether5-gateway
add action=drop chain=output comment=\
    "Drop pings to 8.8.8.8 if they go through PROVIDER2" dst-address=8.8.8.8 \
    out-interface=ether5-gateway
    out-interface=ether1-gateway
add action=masquerade chain=srcnat comment="defconf: masquerade WAN2" \
add comment=PROVIDER1 distance=1 gateway=192.168.7.1 scope=11
add comment=PROVIDER2 distance=10 gateway=192.168.8.1
add comment="Force test pings through PROVIDER1" distance=1 dst-address=\
    8.8.8.8/32 gateway=192.168.7.1
/ip service
set telnet disabled=yes
set ssh port=6222
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Bucharest
/system ntp client
set enabled=yes primary-ntp=84.232.245.55 secondary-ntp=82.77.52.43
/tool e-mail
set address=mail-server-ip from=mail@mail.com password=password \
    start-tls=yes user=mail@mail.com
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool netwatch
add comment=CheckCon down-script="/ip route set [find comment=\"PROVIDER1\"] d\
    istance=20\
    \n/ip route set [find comment=\"PROVIDER2\"] disabled=no\
    \n/tool e-mail send to=\"admin@mail.com\" body=\"Connection with PROVIDER\
    1 Lost, Switched to PROVIDER2 \" subject=\"LOCATION\
    \_Lost connection with PROVIDER1 \"\
    \n/ ip firewall connection remove [find dst-address=\"VPN-IP\"]" \
    host=8.8.8.8 interval=5s timeout=2s up-script="/ip route set [find comment\
    =\"PROVIDER1\"] distance=1\
    1 Regained, Switched back to PROVIDER1\" subject=\"LOCATION \
    Regained connection with PROVIDER1\"\
    \n/ip firewall connection remove [find dst-address=\"VPN-IP\"]"
Cheers,
Alex
i think you need some Nat rule or exception for Router Self-Generated connections
Could you elaborate? Im not really following.
