heres my up scrip
ip route set[find routing-mark=main] gateway=192.168.1.1
this scrip has work for years and on all upgrade until ver 3.10
any help would be great
heres my up scrip
try
/ip route set [find routing-mark=main] gateway=192.168.1.1
I try your forward slash
it still dose not work ![]()
thanks for your reply skillful ![]()
Copy the code to a terminal prompt and see if it works.
Alternatively, Upgrade to ROS3.22. It works for me.
well ROS 3.22 works again thx skillful ![]()
I did the upgrade on a test box and now I have to schedule maintenance downtime for my customers ![]()
At v6.x you must use:
[admin@WAN] > /ip route set [ find where !routing-mark !dynamic ] gateway=192.168.1.1;
