I need a script that will use netwatch to check the status of a gateway every 30 seconds, and disable a static route if the gateway is unreachable. Every 30 seconds it should check again, and re-enable the route if the gateway is reachable again. This is for connection failover from cable to DSL. I’ll be glad to pay for a script like this if it hasn’t been done before. Any help is appreciated!
if possible can anyone show me step by step with photos because its very difficult for me to achive that but i dont want ping gateway to control the link example ping http://www.google.com(74.125.39.104) Every 30 seconds it should check again , and re-enable the route if the second gateway if the http://www.google.com(74.125.39.104) isreachable again
