Netwatch with some modification required
Hi There
i need script to change interface ip if the destination ping timeout we have 4 public ip e.g 10.0.0.2, 10.0.0.3, 10.0.0.4 and single gateway 10.0.0.1 According to check every ip one by one
:local i 0; {:do {:set i ($i + 1)} while (($i < 5) && ([/ping 72.14.207.104 interval=3 count=1]=1)};
:if ($i=5 && [ /ip address set 2 address=10.0.0.2]= ([/ping 72.14.207.104 interval=3 count=1]=1)false) ($i + 1)} while (($i < 5) && ([/ping 72.14.207.104 interval=3 count=1]=1)};
:if ($i=5 && [ /ip address set 2 address=10.0.0.3]([/ping 72.14.207.104 interval=3 count=1]=1)=false) ($i + 1)} while (($i < 5) && ([/ping 72.14.207.104 interval=3 count=1]=1)};
:if ($i=5 && [ /ip address set 2 address=10.0.0.4]([/ping 72.14.207.104 interval=3 count=1]=1)=false) }
hi there
waiting for solution
Chupaka ! normis ! scripting master !!
Hi pokemon,
I am not ignoring you. I am just not sure what you need. There is only one gateway (10.0.0.1), correct? If it is down, I am not sure what good it would do to change your interface IP address.
thanks for your response actually some of our client using DDC Mirc chat due to some issue the admin block the ip addresses. e.g host addresses irc.eunet.net now i need if the ping not answer with the following host my ip public ip change then trying to ping again. 2nd time again ping to host again not answer change with another ip. we don’t need to change or disable gateway
So you need a script to get around an IP blocker (like I use) used by some network admin (like I am) so you can continue what he/she wants you to stop? Is that it?
you are right !
SurferTim waiting for script !
lol SurferTim :slight_smile:
To be honest, if the admin doesn’t just block the sites then all power be to whoever bypasses his system and teaches him a valuable lesson. However if the reason the admin’s blocking isn’t working is due to a system issue perhaps you could recommend him a suitable mikrotik router in return for him removing his block rules :slight_smile:
Hi omega-00
I will help anyone protect themselves from a hacker, but I will NOT assist anyone in their quest to become one, as impervious as my system is to that type attack.
