I 'am using netwacht to monitor ipsec tunnels & change the ip, but often I notice that the dyndns update is too slow and it fails. Is it possible to repeat the down script until the netwatch ping is Up again ?
Or is the only solution, make a schedule, activate it when netwacht see down and deactivate the scheduler on up ?
That seems for me a lot of work when you need that xxx times.
Any other solutions ?
